true trac and 4.30s
Well my rearend is about to explode in my truck and i guess its the best time to go ahead and put gears infront and rear while im at it.. Im gunna run 4.30s and a true trac in the rear.. wheres the best place to pick up a true trac with the best pricing ? btw its a half ton truck 10bolt rear and i need gears for the front diff too what would be the best gears to go with ? and place to get em?
thanx, Garrett |
https://www.performancetrucks.net/fo...ight=gears+ron
I can't find any 4.30s on his site tho. Just 4.11 and 4.56 http://cgi.ebay.com/ebaymotors/GM-8-...Q5fAccessories http://cgi.ebay.com/ebaymotors/GM-8-...Q5fAccessories And these are one that come with a tru trac like posi and gears http://cgi.ebay.com/ebaymotors/GM-CH...Q5fAccessories http://cgi.ebay.com/ebaymotors/GM-CH...Q5fAccessories Tru Trac http://cgi.ebay.com/ebaymotors/GM-8-...Q5fAccessories Motive 4:11 http://cgi.ebay.com/ebaymotors/GM-CH...Q5fAccessories Motive 4:56 http://cgi.ebay.com/ebaymotors/GM-CH...Q5fAccessories |
As i've stated in every thread asking this question.
Rons Machining Services on Ebay. Motive Gears don't whine rear as you stated is 10 bolt 8.5/8.6 Fronts I don't know. If you call Rons he can help further. What makes you think your rearend is about to explode? Spiders making noises? |
Originally Posted by viciousknid
(Post 4390883)
Rons Machining Services on Ebay. Motive Gears don't whine rear as you stated is 10 bolt 8.5/8.6 Fronts I don't know. If you call Rons he can help further. What makes you think your rearend is about to explode? Spiders making noises? the the g80 is locked to the left and will not unlock... with just normal driving no spinning its staying locked up and the whole freakin truck shakes when turning to the left.... and it has 140k on it |
You thank him and not me? And I did all the work? See if I help you anymore:321:
Originally Posted by AJII
(Post 4390888)
THANK YOU AJ:D |
But the guy that posted up above has 4.30s...so maybe you have to call and get those??
(Post 4390897)
We will see my friend..we will see...
But no matter what...You'll always be uglier :punch: |
Yuck. Got luck to have a warning on that one.
