Truck starts in 2nd gear
Old Nov 9, 2011 | 11:33 AM
  #31
probuilder1's Avatar
Your talking about my vette servo? I was thinking about that the other day. Im gonna pull that out when I get home.
Old Nov 9, 2011 | 03:18 PM
  #32
I pulled the servo and checked everything out and everything was perfect. Next thing I'm gonna do is pull the valve body and put the factory 1-2 shift valve back in.
Old Nov 9, 2011 | 05:41 PM
  #33
Vince B's Avatar
You do not need to pull the valve body to put the factory valve back in. Just pull the solenoid and it should be accessible. Also make sure that the white inner spring is in the bore. When you installed the valve did you install the gold check ball in the bore and then the green spring in the end of the valve? I would verify that this is correct and also that the holes in the valve are not plugged with any flashing from when the valve was manufactured. Vince
Old Nov 9, 2011 | 05:55 PM
  #34
Yea I checked that valve and it was clean and installed correctly. Im waiting to see if I can use my autocal to see if the computer is commanding first.
Old Nov 26, 2011 | 06:42 PM
  #35
Got an update for yall, I got a valve body from a friend and swapped the shift kit over and everything works great, now I just need a tune.
Old Nov 26, 2011 | 08:13 PM
  #36
Gilbert@Ace Racing's Avatar
FormerVendor
Good for you! Thanks for the update. Glad you got it worked out.
When you swapped the parts did you see anything that might make you second guess it? Just curious what the diagnosis was?
g
Old Nov 26, 2011 | 08:17 PM
  #37
BlackGMC's Avatar
Resident Retard
Glad you got it fixed, you had two of the best and most helpful tranny guys in your thread.
Old Nov 26, 2011 | 08:27 PM
  #38
I was looking out for something out of the blue but everything I swapped over went in the same way so I'm stumped on what it was. Thanks for all the advice guys.
Old Nov 26, 2011 | 08:54 PM
  #39
Vince B's Avatar
Thats great news that you got it fixed. If you want to get nuts start pulling the valves out and look for burn like marks on the valves. This will more than likely show you if you have worn bores.
ferrellrooster
Mar 6, 2025 03:22 PM
wrb002
Aug 31, 2015 12:00 PM
Ketis
Jul 23, 2015 12:37 PM
black6spdz
Jul 16, 2015 01:32 AM
lxcoupe
Jul 14, 2015 10:14 PM
