Transmission troubles again
Old Dec 25, 2005 | 06:40 PM
  #31
thunder550's Avatar
High on diesel fumes
OK just went out and played around a little bit. Both ds's are still off. With the x-fer case in N I can spin the rear one freely in either direction and the front one will spin with it. With the x-fer case engaged in any manner (2hi, 4hi, 4lo) and the tranny in any gear (R, N, D) I can spin the rear ds counterclockwise (when looking from rear of truck to front), but not clockwise. Front ds turns with it like it should. I think you guys are right about the trans. ****. I will drain the fluid and drop the pan tomorrow and see what comes out.
Old Dec 26, 2005 | 01:18 PM
  #32
thunder550's Avatar
Well something definitely went
Can you see what's wrong with these pictures??
Old Dec 26, 2005 | 01:22 PM
  #33
gonzo 6.2's Avatar
Busted input drum or sunshell with the back of the case broke,due to ,to harsh of shift on the 1-2,band slamming to hard
Old Dec 26, 2005 | 02:15 PM
  #34
DrX's Avatar
DrX
You mean mine's not supposed to look like that? Lost 2nd gear. Some grit in the pan and a few small bits of alloy like yours. Just freewheels when I command 2nd. All other gears seem to work OK.
Tranny's sitting on the floor waiting for my FLT Level 5 65E with billet output shaft and PI converter to get here.
calsdad
Jun 14, 2023 11:07 PM
bearden86
26
Nov 15, 2015 03:58 PM
dsbodley
Nov 14, 2015 09:46 PM
nabozny21
Oct 17, 2015 07:47 PM
jscherbs
Sep 30, 2015 07:54 AM
