is it the transmission or something else?
Old Feb 5, 2009 | 04:09 PM
AudioPh1x's Avatar
Question is it the transmission or something else?
ok so my dads truck is sputtering around the 1700-1800rpm range and we thought it had something to do with the motor but it ONLY happens in overdrive. when we hit the tow/haul it dont do it anymore... any help?
Old Feb 5, 2009 | 05:22 PM
performabuilt's Avatar
LS1TECH & Trucks Sponsor
I would guess the lockup clutch TOW/HAUL mode increases line pressure. If the converter clutch is failing where it may chatter at normal lower pressure it may hold at higher line, Also the PWM strategy is changed some what also which could point to a clogged PWM solenoid or a worn bore for the converter regulator valve.
But I would say its trans/converter related. How many miles on the truck/trans?
Old Feb 5, 2009 | 07:15 PM
AudioPh1x's Avatar
bout 140 on both
calsdad
Jun 14, 2023 11:07 PM
bearden86
26
Nov 15, 2015 03:58 PM
dsbodley
Nov 14, 2015 09:46 PM
nabozny21
Oct 17, 2015 07:47 PM
jscherbs
Sep 30, 2015 07:54 AM
