Transmission Question
Old Mar 25, 2006 | 09:52 PM
StrokerAce03's Avatar
Originally Posted by myclone
The 60e is not an electronic th350 and arent related in any way that Ive seen, read, or heard of. However, the 60E is an electronic version of the 700R4. The break down is basically like this:
700R4=non electronic controlled 4spd OD trans
4L60=700R4 when GM decided to change the name in the early 90s.
4L60E=Electronic controlled 700R4/4L60 (thats where the E comes from).
Old Mar 27, 2006 | 10:17 PM
hog's Avatar
hog
I agree with all of what Hog said about the 60E vs the 80E as far as ratios and what not. The gear spread between 1st and 2nd is not NEARLY as bad in a 80E compared to the 60E. The deep (lower) first gear in a 60E makes a vehicle with moderate power accellerate like a more powerful vehicle but the huge jump on the 1-2 shift really pulls the motor WAY down in rpm (and breaks parts on a high tq vehicle). The 80E's closer ratios may not give you as much of an explosive off the line accelleration as 60E in a moderately powerful vehicle but the ratio difference between 1st and 2nd is not nearly as dramatic so its easier (IMO) to keep the engine at peak hp throughout the test.
BTW, the 80E does have bands....two of them to be exact compared to the 60E's one band. However, one band of the 80E is prolly heavier and has more friction surface than two 60E bands LOL. Comparing the internals of a 60E to the internals of an 80E is like comparing a 100lb weakling to a 350lb power lifter....as in no comparison and the 80E is a brute of a trans hands down.
Thanks for setting me straight about the bands.
peace
hog
Old Mar 27, 2006 | 11:09 PM
James B.'s Avatar
The 4L80-E has two bands but they are only used for overrun in manual gear selection and for reverse. The bands in the 4L80-E are NOT used to upshift or downshift!
The band in the 4L60-E is as overworked as the undersized POS 3-4 clutch pack in the thing. The band in the 60 has to upshift both the 1-2 and the 3-4. To make matters worse it engages against a drum made of ALUMINUM!!! That's right - aluminum as a friction surface! It's pathetic. The 80 may have two bands but they're not for shifting and they contact against hardened STEEL drums!
The 4L60-E and every itteration of it (4L65-E, 4L70-E, etc) are all money pits. It's a ****-poor design intended for economy that has somehow ended up a staple in the GM RWD powertrain lineup. If I sound biased, well, I am - but for good reason having been there and done that. You can tell the ones who sound like I do. Truth be told they've each been through a few 60's themselves too.
Old Mar 28, 2006 | 12:50 AM
myclone's Avatar
Right on brotha . After blowing up two dozen (I quite counting at #22) 700/60Es nothing but 80Es for me from now on unless its in something that will stay stock.
Ok, there is a use for the 700/60e now that I think about it. IIRC I got ~30 bucks out of the last truck load of blown up trans parts and cracked cases I hauled to the metal recycler. They were all 700s or 60E's so I guess they are worth a little something after all LOL.
Old Mar 28, 2006 | 01:07 AM
James B.'s Avatar
...the last truck load of blown up trans parts and cracked cases I hauled to the metal recycler.
Ha! They should feel at-home there!
Old Apr 5, 2006 | 09:04 PM
'JustDreamin''s Avatar
Originally Posted by screamingjimmy
Parasitic losses for the TH400 is 45hp, the TH350 takes 30hp and the powerglide take a staggaring 20hp.
The link you provided doesn't have any concrete evidence about Parasitic losses. Guy says "If I remember correctly, I read something somewhere that said" 45hp....
I expect that the TH400 may use a bit more power than the TH350 while operating at identical power / performance levels, due to bigger heavier parts, and a bigger oil pump. HOWEVER, a large portion of parasitic loss is directly related to line pressure (ie, how hard the pump is working).
Powerglides doing drag duty behind big blocks with super high line pressures probably consume 60hp, not 20hp. And parasitic losses are a undoubtedly vehicle and situation dependent and are NOT something you can accurately apply a universal blanket statement to.....
'JustDreamin'
Old Apr 5, 2006 | 09:17 PM
nightrunner's Avatar
Mr. Obvious
where does the 4l70e come from?
Old Apr 6, 2006 | 12:31 AM
James B.'s Avatar
The Trailblazer SS has that between a LS2 and 9.5" SF rear, in both 2WD and AWD.
Old Apr 6, 2006 | 04:07 PM
torx's Avatar
Originally Posted by SSlow 4.8
these transmissions arent made to handel a mass amount of hp... its meant to tow to its capabilities and meant to be driving NORMALLY.. not how we race them, lol. But a well built 4l60e or 65e (same thing basically) can be built up to handle in the ballpark of 500rwhp w/o t/m. Only problem with 4l80e is that it robs a lot hp, more so than through the 60e drivetrain... 4l80e is a good idea if your eventually wanting to go FI or build a motor in the 500+ hp range.
In the GM service manual it says the 4l60e's maximum trailer towing capacity is 13500 lbs, and a maximum gross vehicle weight of 8600 lbs. LOL
4=four forward gears
L=longitudinal mount
60=product series
E=Electronic Controls
Old Apr 6, 2006 | 08:46 PM
And if you believe them, can I interest you in a nice bridge in New York City???? Or maybe on in San Francisco?
'Dreamin'
