Transmission overheating
Old Dec 6, 2007 | 10:11 AM
2000SSilver's Avatar
Default Transmission overheating
My transmission starts to overheat after about 30-40 minutes of driving. It's a new problem and began about a week or two after I had the TC installed. Otherwise it drives characteristically fine. The fluid level is fine. It has a TCI 3k stall and my sig is current. Please help.
Old Dec 6, 2007 | 10:59 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Did you install an aftermarket cooler? Recommended.
How hot is your fluid getting? How are you measuring it?
Is your TC locking?
Old Dec 6, 2007 | 11:13 AM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Curious to know the operating temp you see.
Old Dec 6, 2007 | 11:33 AM
Is your TC locking?
I only have the factory GM cooler and for the first 2-ish months after the TC install, it didn't overheat. It goes over 200, keeps climbing and I get the "transmission hot" message in my display center. Measuring it with the cluster gauge. How do you know if the TC is locking? I'm not a transmission guy! Would it run if the TC was going bad?
Old Dec 6, 2007 | 11:56 AM
bluecajun5.3's Avatar
11 Second Truck Club
sounds too me that the lockup clutch isn't engaging anymore.
have you noticed if your turning more rpms at say any given mph than usual?
yes it will still run if the tc was going bad.
Old Dec 6, 2007 | 11:59 AM
Yeah, that was the only small difference I noticed. Seems to hang up between shifts occasionally and stays in upper RPM's a little longer before shifting. Don't think replacing the cooler would help??
Old Dec 6, 2007 | 12:05 PM
https://www.performancetrucks.net/fo...d.php?t=406094
This was my original thread. It's a little more descriptive.
Old Dec 6, 2007 | 04:45 PM
Bish's Avatar
A good way to test lockup is while cruising on highway. Tap brake without reducing speed and the rpm's should jump up a bit then drop back down in a couple seconds when it locks again. If it is not locking, I could see it overheating. Could also see it with a 3000 stall on a stock cooler.
Old Dec 7, 2007 | 11:49 AM
95ImpSS's Avatar
calsdad
Jun 14, 2023 11:07 PM
bearden86
26
Nov 15, 2015 03:58 PM
dsbodley
Nov 14, 2015 09:46 PM
nabozny21
Oct 17, 2015 07:47 PM
jscherbs
Sep 30, 2015 07:54 AM
