Transmission Lines...
Old May 17, 2010 | 12:30 PM
nonnieselman's Avatar
This right here is the easiest way!!
Old May 17, 2010 | 12:32 PM
EVILGMC's Avatar
yes, that would be the way....especially if the trans is out.
where you find those nifty little bits?
Old May 17, 2010 | 12:53 PM
fastnblu's Avatar
Originally Posted by EVILGMC
i am running a hybrid....part factory lines and part -06. the stock lines run from the trans to roughly the a/c compressor. then tube nuts and a union to AN. -06 from there to my setrab cooler. jegs has the compression to -06 or you can use a tube nut and sleeve if you have a flare tool....
or run all braided if its easier, or if the trans is out.
While I'm not running an 80E, & hope I don't ever have to, that's exactly the best time to do them.
I was just mockin up the fitting & end after I got the remainder of the ones I needed. I took measurements best I could by myself yesterday on how long the lines needed to be so I know what I need. It's close, but it'll be more than enough. I built in a margin of error. I wanna do a few tidbits like this to minimize downtime & visualize it. Cooler can be mocked some now, then I'll tighten later w/. wrenches in my soft jaws, & complete when trans is swapped.
AN fittings can crack the case
Gotta be careful!
I got some cool lil adapters that connect into your factory fittings and have -6AN male threads on the other side.. This right here is the easiest way!!
So I've been told. I was told those w/. the crush washer stop that crackin from happening. Where did u find those Jonathan?
Also, there are quick connects out there. I've heard they minimize the flow.
Last edited by fastnblu; May 17, 2010 at 01:04 PM. Reason: Mock up in advance if u have the time or need to see.
Old May 17, 2010 | 01:14 PM
silver-mod-o's Avatar
Hunt&Fisherator
I used the same fittings. Vince showed them to me. I think they were about $17/pr
Old May 17, 2010 | 01:59 PM
SnakeOiler's Avatar
Gotta be careful!
Only if you use the wrong threads
Old May 19, 2010 | 10:41 PM
02_2500avalanche's Avatar
anyone know who sells those tci fittings? couldnt find them on their site...maybe im just an idiot
Old May 20, 2010 | 10:00 AM
i was told by Vince that the threads arent 1/4" NPT but its close enough to work.. but if you tighten them down too tight it will crack the case.
Figured he knew what he was talking about..
Old May 21, 2010 | 02:26 PM
DixieDevil's Avatar
Thanks Jonathon, wish I would have done this before! Does FLT have those fittings?
Old May 21, 2010 | 02:32 PM
fastnblu's Avatar
While FLT may or may not have in stock, go to purechoicemotorsports.com
Old May 21, 2010 | 02:33 PM
DixieDevil's Avatar
Thanks man
