Transmission HELP
Old Aug 29, 2010 | 10:21 PM
HuskerZ71's Avatar
Default Transmission HELP
First off, I tried SEARCH. There are so many topics with trannys it's overwhelming. Hopefully someone can help.
My truck is bone stock, 106K miles. I drive it like an old man. I dont take off fast, WOT or anything like that. Literally, like an old man!
Today I was driving down the highway and after about 15minutes and several stop lights later I was stopped again at a red. The light turned and I proceeded to take off like normal and the RPM's went up to around 1500 or so like I was in nuetral. The truck then lurched forward and drove like normal. This was not a violent thing (others in the vehicle didnt notice). This didnt happen again for the rest of the day.
Later on when the truck was in 4th with the TC locked I could feel a slight vibration at certain times with a little throttle. Again this was not noticed y anyone else, it was very slight.
I got home and checked the fluid. The vehicle had just been driven and was at operating temp. The fluid was full and looked new, red, no dark tinge. I have put 10k miles on this truck since I got it and havnet done a thing with the tranny.
Could this be a sign of a serious tranny problem or could it be the torque converter? Compared to our experiences what do you think? Again I dont drive as spirited as alot of the people on here talk about.
Old Aug 30, 2010 | 07:07 AM
FLT's Avatar
FLT
FormerVendor
Husker few things come to mind. Either you are getting ready to have an input sprag failure, forward clutch failure, cracked 1-2 accumulator piston or you have a partially cracked forward accumulator piston. The forward and 1-2 accumulator could be easily checked and if it is plastic they are known to crack. The forward one would be more like a neutral feeling and the 1-2 would start out in second gear for a split second and then go back to first depending on how bad it was damaged if this were the case. The other two I have listed would require a tear down of the transmission in order to be fixed. Vince
Old Aug 30, 2010 | 11:02 AM
HuskerZ71's Avatar
Thanks! It was really more of a "neutral" feeling. I really hope I can fix this cause I cant afford a $2000 trans yet.
calsdad
Jun 14, 2023 11:07 PM
bearden86
26
Nov 15, 2015 03:58 PM
dsbodley
Nov 14, 2015 09:46 PM
nabozny21
Oct 17, 2015 07:47 PM
jscherbs
Sep 30, 2015 07:54 AM
