Transmission/ext housing mating issue
Old Aug 7, 2011 | 05:19 PM
dmelvin's Avatar
Default Transmission/ext housing mating issue
Guys... I've been fighting this for nearly a month now, and I'm about at my wit's end. I've got a pretty substantial trans leak where the ext. housing mates to the transmission, it's my fault, I overtorqued the bolt and pulled the threads out. Well this weekend I pulled it all apart and heli coiled it... it's still leaking. So I figured I'd run this by you guys before just doing it. Is it going to hurt anything if I run a bead of RTV and make a gasket there? It's about the only thing left I can think of that may be able to fix my issue.
Thanks guys.
Old Aug 7, 2011 | 05:24 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
If you take it apart & can't see anything else wrong, I think a small bead of sealant might be a good idea.
Check it really closely for small cracks while it's apart.
Old Aug 7, 2011 | 11:07 PM
Vince B's Avatar
Denton is the same vehicle in your sig with the vibration? If so check that housing as mentioned above. I have seen them crack in the past as well. Also make sure there is an oring on that housing going into the trans. If you need a new one just let me know. I think I might have a few laying around. Vince
Idryfly5
Sep 2, 2022 08:55 PM
kha4079
Oct 29, 2018 04:38 PM
Superman09
Sep 25, 2015 05:55 AM
MA$TER_E
Sep 9, 2015 03:14 PM
