Transmission cooler lines
How do the cooler lines run from the transmission? Does it go through the radiator first then the cooler or the other way? Why does it go through the radiator at all ? Just wondering cause I was pulling a camper through Colorado and it was causing my transmission to get to 220 degrees and then my truck was getting up to 230. I have a Trucool cooler but it was not enough I guess.
We will see today. Going to put stainless tubing valves on a bypass loop. I will be able to bypass or go through the radiator when ever I feel the need with a quarter turn of a valve.
Nimoryan
07-05-2015 03:50 PM
1500, chevy, cooler, external, gm, heat, line, lines, performance, proof, radiator, run, tranmission, trans, transmission
