Transfer Case Teardown NP261
Old Jun 14, 2013 | 09:19 PM
Atomic's Avatar
I have a gauge for that
Default Transfer Case Teardown NP261
So I heard some weird noise coming back from the track last night and since I was taking the torque converter out anyway I figured I may as well see what kind of damage the tcase is taking. I am probably the hardest person on a transfer on this site besides maybe stock48, but my truck is heavier (5000 with me) than his so I was curious.
I have put about 3500 miles on it in the last year and a half. Probably have an honest 150 4wd-hi launches with 4 drag radials on this tcase with at least 600+hp. Its a stock unit, 250,000 original miles. Only thing that has been changed is the fluid, 80e input gear, and added one of those pump saver things when I did the input gear. It is the manual floor-shifter version.
Just slight wear on the pump saver thing. Back case half still looks perfect.
Magnet is pretty gross...I am guessing most of the material is from the chain.
And the only actual damage I could find was the bushing for the mode fork.
The reason there is so much play in the front dshaft typically is because the ONLY thing transfering power to the front is the middle row of teeth. Notice the big spaces in between them.
When you shift into 4wd, the shift fork pushes that outer sleeve down onto that row so it looks like this:
Here is a view of the input planet assembly...this is pretty cool. The gear on top fits inside the assembly. When in 2wd it fits all the down on the furtherest row of teeth. When you move it to neutral the mode fork pushes it up slightly so it is between the two rows. And in 4lo it moves it to the top most row of teeth, which is how you get the gear reduction of 4lo.
And here is the whole assembly stood on the input shaft. Notice the shift and mode forks.
I plan to replace the chain and that mode fork, as well as the input and output seals, but otherwise everything looked perfect, especially considering the hell I give this thing.
Old Jun 14, 2013 | 09:45 PM
fortplainman's Avatar
Ah those links and pins of that chain brings back memories working at borg warner. I dont know how many damn studies i did for surface roughness, tolerances, and such on them damn things lol.
Old Jun 14, 2013 | 10:14 PM
brent1976's Avatar
11 Second Club
These transfer cases are tough. I've put 50k+ miles on mine since the turbo went on(600+whp) and before that it was a heads/cam 6.0L. I did the 80e input, a new chain, and the wear clip about 55k mile ago, but the transfer case has 178k total. I have done hundreds of 4wd launches(every time I get the chance), and in the winter I use 4wd a good bit, because it's fun, but a little hairy driving in snow and ice with that much power.
Old Jun 15, 2013 | 06:48 AM
TIM Z's Avatar
11 sec. Truck Mod
That's awesome to see how well they handle the abuse !
Everyone always asks if the Tcase can handle the 4x4 launches , here's proof
Old Jun 15, 2013 | 08:53 AM
thunder550's Avatar
High on diesel fumes
I think I remember reading somewhere that the limit on those things was like 2500 ft-lbs. Totes cray cray!
Old Jun 15, 2013 | 09:14 AM
chevrolet all the way's Avatar
that is really impressive its holding up as well as it is! hardly any sign of wear after some serious abuse.
Old Jun 18, 2013 | 12:52 AM
ls6musclehead's Avatar
Parish8 had posted that years ago on the Blue truck build that did 1000hp with the single turbo.
Old Jun 18, 2013 | 12:59 AM
ak2007r6's Avatar
Awesome post. Thanks for showing the internals and how it all works. Never seen the inside of a tcase before
Old Jun 19, 2013 | 06:24 AM
JR 427's Avatar
Is the floor shifter version known to e any stronger than the or operated electronically?
Old Jun 19, 2013 | 09:29 AM
Atomic's Avatar
I think the inside is the same. Just instead of a lever you have a motor to turn the mode cam...no chance id that motor failing with the floor shifter version
