Trans Shifting
Old Mar 15, 2009 | 04:25 PM
JDC's Avatar
JDC
Default Trans Shifting
I have a 03 Envoy and the trans is acting up when you put it in gear and give it throttle the trans hesitates and then bangs into gear, but if you put it in gear and sit for a few seconds its ok. Do you think it could be a cracked 1-2 servo. or what do you think.
Old Mar 15, 2009 | 05:30 PM
FLT's Avatar
FLT
FormerVendor
Check your fluid level. Sounds like it might be low. Does it do this in forward and reverse?
Old Mar 15, 2009 | 06:15 PM
JDC's Avatar
JDC
Just seems to do it in drive the fluid is a little dark I am changing the filter and fluid tomorrow. once driving down the road and you step on it seems to work fine with no slipping.
Old Mar 15, 2009 | 07:12 PM
FLT's Avatar
FLT
FormerVendor
Tell you what before you drive it next time check the fluid level with the engine off. Then start it up and look to see how far it goes down. I think you might be having a converter drain back problem which is usually caused by lose bushing inside the trans. It is possible that you have a worn or cracked forward accumulator piston. This is located on the valve body under a cover with three bolts. Be careful if you remove this cover because there are a couple springs in there that you do not want to lose. Vince
Old Mar 25, 2009 | 06:20 AM
JDC's Avatar
JDC
Ok I changed the filter and fluid and the forward accumulater ***. and it still gos in to gear hard if you dont wait a few seconds. if it has a bushing spun in the housing are there over sized ones to replace it or is the casing junk now if this is the problem. Ill check the level tonight before its started and after.
Old Mar 25, 2009 | 11:36 AM
white lightning SS's Avatar
This is what my truck did when the input clutch was smoked.
ferrellrooster
Mar 6, 2025 03:22 PM
Fast86z
Aug 23, 2015 12:35 AM
lxcoupe
Aug 10, 2015 12:20 PM
lxcoupe
Jul 14, 2015 10:14 PM
1987cut
Jul 12, 2015 09:59 PM
