trans overheating with 40k cooler?
Old Jan 14, 2012 | 07:15 PM
  #31
david0982's Avatar
Electric fans.
Old Jan 14, 2012 | 07:17 PM
  #32
AKlowriderZ71's Avatar
11 Second Hall Moniter
Maybe they aren't pulling enough air? What are your fan settings?
Old Jan 14, 2012 | 09:21 PM
  #33
david0982's Avatar
One fan is always on ans the other one comes on when the A/C turns on.
Old Jan 14, 2012 | 09:49 PM
  #34
dmelvin's Avatar
Originally Posted by 1fast06
that could be 1 of the reasons it gets so hot cause u by pass the radiator
What? That's one of the reasons it shouldn't be getting hot.
Sorry I don't have any advice that hasn't been given already... But I saw this comment and had to say something about it. FWIW - my 60e has troubles staying over 100 with 25 degree temps going down the highway. So something in the transmission has to be causing this. Maybe a clutch not disengaging completely?
Old Jan 14, 2012 | 10:20 PM
  #35
Atomic's Avatar
I have a gauge for that
Seeing this comment irritates me, and you arent the only one who ive seen post this. The only instance when having the trans hooked up to the radiator cooler as well as the a huge cooler such as the trucool will help, and this is important, is if the trans temp is hotter than the engine radiator temp. The engine rad typically runs around 200 degrees which is far warmer than you want your trans temp. Heat is always conducted from hot to cold.
With that in mind, I would recommend still using the rad cooler if you live in very cold environment for prolonged periods, like the northern US states or Canada.
As far as the OPs problem, where is the cooler mounted? If there isnt airflow from the grille, even with a fan it is going to get pretty warm.
Old Jan 16, 2012 | 01:00 PM
  #36
david0982's Avatar
Here's how the coolers mounted.
Old Jan 16, 2012 | 01:04 PM
  #37
Do the trans temps come down when you're driving on the highway(55+ mph)?
Old Jan 16, 2012 | 01:06 PM
  #38
Frostflowz's Avatar
check for any crimps in the line, a slight clogged line will make temps jump very quickly.
Old Jan 16, 2012 | 01:57 PM
  #39
david0982's Avatar
Haven't really driven it very far because of this problem but it seems like the temps just keep increasing as I keep driving. But I have not driven it for longer then 30 minutes since the swap so IDK how high the temps would get if i drove it longer. The highest its went is around 200 and that was after a 30 minute drive taking it very easy. I checked both lines to c if they were flowing properly and they seem to be fine.
flatblack83
Jan 3, 2026 07:10 PM
ullose272
Aug 5, 2016 02:05 PM
GRRR65GTO
Aug 17, 2015 11:33 PM
Ls3silverado
Jul 31, 2015 04:22 PM
ferrellrooster
Jul 17, 2015 07:07 AM
