trans overheating with 40k cooler?
Old Jan 13, 2012 | 02:07 PM
mhotrodscooter's Avatar
When I was having troubles with mine running hot. My trans would whine in first gear for some reason. Then oneday the whine and running hot was over,Fixed itself.
Old Jan 13, 2012 | 03:15 PM
AndysC3's Avatar
With e-fans mine doesn't get above 160 in stop and go traffic. But I do have a 60 E. And it gets into the 70s here in the winter.
Old Jan 13, 2012 | 03:23 PM
david0982's Avatar
Yes It does have a whining noise in first gear but I don't no what's causing it. Anybody know what's causing this?
Old Jan 13, 2012 | 03:44 PM
Wish I could help more, but when I made my thread I never mention it cause I thought it was normal, but when gauge stop reading hot the whine was gone.. All I had is a heat gun to check temps. Mine would hit 260* sometimes, but heat gun only would show 185*
Old Jan 13, 2012 | 03:45 PM
nonnieselman's Avatar
Mine whines 1st really bad. But most them i heard with 100k+ miles on them are gonna whine.
My brothers with 315k miles sounds like a old eaton roots blower.
Mine runs about 100* if its 32* ambient. Takes forever to warm up enough to lock up.
Sounds like you have a slipping problem or not enough air flow over the cooler.
Old Jan 13, 2012 | 03:51 PM
1fast06's Avatar
that could be 1 of the reasons it gets so hot cause u by pass the radiator
Old Jan 13, 2012 | 04:14 PM
That's about what mine sounded like and I only had 69k on the clock lol
Old Jan 13, 2012 | 04:59 PM
david0982's Avatar
Well I wish mine would fix itself. lol Just talked to a local trans shop and he told me that I most likely have a torque converter lockup issue but I can fell the converter locking up but maybe its just partially locking?
01silvy's Avatar
I would check your converter lock up % with the scan tool.. if it is slipping excessively it will cause high temps.. i would also check your air flow across the cooler.
Old Jan 13, 2012 | 08:40 PM
My trans cooler in the radiator was clogged when i got it so i bypassed it and only running the trucool 40.
I wish i could run it in the radiator so it would warm up quicker.
You can log converter slip on your laptop.
