Trans cooler with a fan?
Old Aug 4, 2006 | 04:13 AM
Pjstucn's Avatar
Default Trans cooler with a fan?
Is it worth spending the extra money and getting a trans cooler with the fan on it? While im on the subject, what about getting a deeper trans pan at the same time?
Old Aug 4, 2006 | 05:23 AM
Quik's Avatar
5 year bitches!
every bit of cooling helps. i run a huge cooler 11x11x1.5 a deep pan and i also have a fan on my cooler but not currently hooked up. you want tranny temps low but if you have a small converter wouldnt worry about it. its once youre over 3400 stall thats when it gets bad for heat.
Old Aug 4, 2006 | 07:27 AM
quik, what GVW cooler do you have? i saw a 30000 stacked plate cooler at OPT for 51.99 thats 9 3/4 x 11 x 3/4
Old Aug 4, 2006 | 08:51 AM
Nick™'s Avatar
I'm using a fan off of a Yamaha R6, check ebay and your local cycle dealer for parts off of wrecked bikes. just for reference: my trans temps climb as high as 190* sometimes with a stock converter, white1's temps with a Fuddle 3200 (or is it 3400?) will cool to around 150*. I need to change my thermostat to cool the radiator some and get a bigger cooler cause this ain't cutting it on a stock tranny truck.
Old Aug 4, 2006 | 04:24 PM
Pjstucn's Avatar
i was thinking about one of these http://www.jegs.com/webapp/wcs/store...tegoryId=10535
Old Aug 4, 2006 | 10:33 PM
FLT's Avatar
FLT
FormerVendor
That is a good upgrade option! I believe that if you hook that fan up with a sensor to turn the fan on and off it will be the cat's meow! I do know that you can make a home made kit for alot less!
Old Aug 5, 2006 | 02:04 AM
Pjstucn's Avatar
A home made kit out of what?
Old Aug 5, 2006 | 07:14 AM
a regular trans cooler and then you find a small elec. fan for cheap... that kit is like 200. if you get a trans cooler for like 50 or something and get a small elec fan for between 50 and 80 and just zip tie them together or something you save money and you could just hook it up to a switch or something
Old Aug 5, 2006 | 11:49 AM
Quik's Avatar
5 year bitches!
not quite sure just hte large one from B&M since my old one had issues
Old Aug 5, 2006 | 12:50 PM
closet red neck's Avatar
I have "two" stacked 8 pass, 15 1/2" x 10" x 3/4" (ran inline) coolers and my trans temps will range from 160º to 220º depending on how much I get on it. I don't have fans on my coolers now but the fan couldn't hurt.....Hope this helps.....
James
5.3Okasai
Mar 9, 2022 01:07 PM
GRRR65GTO
Aug 17, 2015 11:33 PM
1slwgto
Aug 16, 2015 06:40 PM
zaathur151
Aug 12, 2015 06:32 PM
ferrellrooster
Jul 17, 2015 07:07 AM
