Based on the data you gave and assuming 10% converter slip you should be crossing the finish line around 5500 rpm at 130mph.
If your at 6500 at 130 mph, then you have about 30.5% slip, either in the converter or trans which is a lot. I'd say you have a problem somewhere |
on the passes where i trap 130-133 im about 6500 if i remember correctly. thats with about a 3600 circleD stall, 28" tires and 3.73 gears
Yeah looks like everything is pointing towards the converter, the tranny fluid looks good so ill take the stall out and get it tightned up some... Blah, thanks again!
It sounds to me like it's time for a more efficient converter. I'd bet you'll notice a nice gain in ET. :)
Never been a big fan of midwest converters.
Originally Posted by Vince B
(Post 4858052)
The ideal thing to have is a loose converter to build boost off the trans brake then lock it up once you get going. Problem is locking a high-stall loose converter is extremely stressful on the converter, especally with a high power setup.
With that in mind, yank is now making a multidisk 80e converter that looks enticing... PI has a 3 and 5 clutch 80e converter... Circle D has a "break it if you can" moto on their multi clutch 80e converters... |
Is there a way to use a lockup 80E converter in a TH400?
^No they are totally different.
You can get lockup for a th400 but it cost a pretty penny lol, alot of the big promod and outlaw guys are doing it with th400 and powerglides
