tranny pump (little story)
Old Jul 22, 2007 | 11:01 PM
joehawkz71's Avatar
Originally Posted by negativeswitches
most people just get a reman pump
you can rebuild them, it's fairly easy to do, but you need access to a metal lathe and someone who knows how to use it if the case is damaged
can youjust get a reman one at the local parts store? i really havent herd of pumps going out!!
Old Jul 23, 2007 | 12:11 PM
joehawkz71's Avatar
did you have the converter on the trans or on the flex plate when you installed it?
what was the clearance from the lugs to the flex plate when the trans was mated?
i put the converter on the tranny first then put the tranny in the truck...the converter has to fall into placeon the shaft and its kinda tricky cause you think its lined up but they you turn it just a smidge more and it falls all the way into place...
for clearance i have not a clue...all i know is that there was plenty of clearance..
Old Jul 23, 2007 | 01:17 PM
04Denali's Avatar
Originally Posted by 1SlowHoe
Your converter probably did this:
Took out your pump and littered the inside of your converter and trans with teflon and metal shavings. First hand knowledge of this Mine did it on a slow pull away from a stop sign. I didn't even coast all the through I was going so slow.
WOW, Looks like mine
Old Jul 23, 2007 | 01:42 PM
joehawkz71's Avatar
ouch! i sure hope i didnt do that to mine! mark how did you do that to yours?
Old Jul 23, 2007 | 02:40 PM
04Denali's Avatar
I was in Texas for a Denali meet, was doing a WOT run and when it went into 3RD it bounced off the Rev limiter and that was all she wrote, was 1700 miles from home, but all worked out in the end.
Mark
Old Jul 23, 2007 | 02:52 PM
negativeswitches's Avatar
well you want as little clearance as possible but not touching when you pull the converter up to the flexplate
there should have been 3 clicks for the t/c to fall into place
Old Jul 23, 2007 | 04:50 PM
joehawkz71's Avatar
it was all the way on!
Old Jul 23, 2007 | 04:54 PM
BlackGMC's Avatar
Resident Retard
How many miles do you have on the tranny?
Old Jul 23, 2007 | 07:15 PM
what i was saying tho was that if it is pulled back to far it wouldent be all the way on anymore lol
Old Jul 23, 2007 | 08:26 PM
nonnieselman's Avatar
I was goin down the interstate one night goin out to eat. Had the cruise set on 70 and all of a sudden the the engine started revving then it was pegged at 6k+rpms before i relized something was wrong..
Come to find out the TC took the pump teeth out...
