tranny is out finaly
Old Jul 22, 2005 | 05:28 PM
black4x4's Avatar
Default tranny is out finaly
finaly got the tranny out of the truck tryed some ideas were i thought to much and finally it came down to using a hammer screwdriver and prybar. and evryone said i would get a waterfall of atf fluid from the torque converter since i had to leave it attached to the the flywheel and not in the tranny but i only got a couple of drops. it should be thumpin by the end of the weekend
Old Jul 22, 2005 | 10:30 PM
black4x4's Avatar
looked around and noticed were i had a punch through one of the holes in the flex plate looks alittle deformed now would i need a new one and if so what does a stock one run for trucks.
Old Jul 24, 2005 | 10:58 AM
Why did you have to leave the verter bolted up?
Old Jul 24, 2005 | 02:42 PM
black4x4's Avatar
because when i went to do my cam i put a punch through a hole in the fly wheel and when i went to tighten the crank bplt it turned it up into the bellhousing and i then couldn't turn the motor over to get to all the bolts so i had to do it with out pulling the converter.
Wolftrk99
Dec 3, 2015 08:12 PM
sTNT971
Sep 26, 2015 06:27 AM
racedad70
Sep 16, 2015 01:51 PM
JordanH
Sep 12, 2015 12:02 AM
mayko
Sep 7, 2015 12:24 PM
