Tranny lines
Old Jan 31, 2011 | 08:51 PM
Default Tranny lines
Anyone block off the transmission lines to the radiator and run them straight to a cooler and back. Is there any benefit to doing this or is it better to run it through the radiator also.
Old Jan 31, 2011 | 08:59 PM
charcold-bowtie's Avatar
Its been debated back and forth. Mine is currently ran thru the factory cooler, and then an aftermarket external. Some like it to help warm up the fluid faster, when u utilize the radiator.
I cant say I have an tranny fluid temp problems
Old Jan 31, 2011 | 09:41 PM
Swerve7rpm2000's Avatar
The purpose of running it through both is that water will pull more heat out than air will, thats why your fluid goes to the radiator first (Transfluid/water) then goes to aux cooler to remove some more heat (Transfluid/Air), if anything delete the aux cooler (Transfluid/Air)......This is coming from my 30 yr experienced trans guy
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
Wolftrk99
Dec 3, 2015 08:12 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 06:27 AM
lxcoupe
Sep 25, 2015 12:36 PM
