traction issues
Old Feb 28, 2012 | 09:08 PM
pillittokillit04's Avatar
Default traction issues
after putting in my 373 and locker and dropping my helper spring to lower it down a bit I tried stalling it up and leaving and all it does is wheel hop terribly now curious if the pinion angle is off that bad due to the helper out or ??? if I leave on the spray it hooks like a champ
Old Feb 28, 2012 | 10:44 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You need to measure your pinion angle no matter what, and add some degree shims if it's off. But, you're experiencing "spring-wrap" because you removed the overload leaf. To counter that, you should install Cal-Tracs or something similar.
Idryfly5
Sep 2, 2022 08:55 PM
TAPyvehc93
Sep 14, 2015 01:22 PM
dselby25
Sep 11, 2015 05:03 AM
MA$TER_E
Sep 9, 2015 03:14 PM
Boyes50
Sep 8, 2015 12:06 PM
