Traction Bar Ground Clearance
Old Mar 26, 2012 | 11:46 AM
JimS's Avatar
Default Traction Bar Ground Clearance
My truck is dropped 4" in the rear so ground clearance is a bit of a problem.
Which aftermarket Traction bars will afford me the most ground clearance?
Old Mar 26, 2012 | 12:25 PM
shakesvho's Avatar
My Silverado has a 4" drop and I use Calvert CalTrac Bars #3400. Never had a problem with ground clearance.
Old Mar 26, 2012 | 12:47 PM
RedHotRodTruck's Avatar
My regular cab is lowered 2/4 with hangers and shackles...no problem with clearance on Cal-tracs. I wish i would of waited for the Assain bars though...seems like they would work better on none flip kit applications.
Old Mar 26, 2012 | 01:04 PM
Boosted_Silverado's Avatar
im 4/6 and theirs no way you can hit them, mine are higher then the body when the trucks on the ground.
Old Mar 26, 2012 | 01:05 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Jim, my muffler hangs down lower than my Cal-Tracs. Here's a pic, 11 inches of clearance.
Side shot of my truck, to give you an idea of ride height.
Old Mar 26, 2012 | 01:09 PM
Ferocity02's Avatar
I believe it would be impossible to hit the bracket on the ground, unless your wheel snapped off.
Old Mar 26, 2012 | 06:11 PM
JimS's Avatar
Thanks you guys!!! Once again this site ROCKS! I ordered my set and they'll be here Friday.
The wheel hop did take out the ring gear.... 3 teeth sheared.
lukn4trbl355
Oct 21, 2015 11:19 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
Alco
Oct 4, 2015 06:58 AM
carid
Oct 1, 2015 09:22 AM
WICK3DxGATA
Sep 24, 2015 06:56 PM
