towing with t56
Old Jul 10, 2013 | 04:00 AM
DAH32's Avatar
Default towing with t56
I currently have a GTO t56 in a 99 silverado with 4.56 gears. Im using a stock corvette clutch and pressure plate.
Is there any downside to me towing my chevelle with this tranny.
The chevelle and trailer are probably right at 5000 lbs.
Should I stay out of the overdrives (5 and 6th) at cruise?
Old Jul 10, 2013 | 07:30 PM
Blackpanther99's Avatar
Just keep your shifts under 2k and try to stay out of 6th gear. Since your towing I doubt youll be trying to shift that high anyways. I know Centerforce's clutches are very good for towing. You might consider at least swapping out your clutch.
Old Jul 11, 2013 | 08:11 AM
Suburbazine's Avatar
I would recommend going no higher than 4th gear, thats a LOT of weight and you will leak power at the clutch (slip) in the higher gears. A stock Corvette clutch has a lot of pressure...for a Corvette. In a truck you get about the same performance as a manual Subaru has.
Old Jul 13, 2013 | 02:31 PM
DAH32's Avatar
Thanks for the recommends.
Old Jul 14, 2013 | 08:02 AM
DAH32's Avatar
Seems like most concerns is for the clutch itself. Any concerns for the internal componets of the tranny. Like 5th or 6th gear?
Old Jul 14, 2013 | 09:17 PM
You'll exceed the limitations of the clutch before you exceed the gearset, unless you put in a super strong clutch and pop the shifts.
I *think* 5th gear is the weak spot in the T56 transmission due to internal stresses.
Old Jul 15, 2013 | 06:56 PM
Agreed^
calsdad
Jun 14, 2023 11:07 PM
AdaMax
May 16, 2016 11:35 PM
cheyenne383
Nov 13, 2015 09:24 AM
SWINGRRRR
Sep 3, 2015 07:49 PM
hackrst
Sep 2, 2015 05:27 PM
