torsion bar and/or suspension experts, I need your advice
Old May 4, 2006 | 05:28 PM
  #21
moregrip's Avatar
what a rush!
Originally Posted by Full_Pull6.0HD
I don't believe the bars would change the front height drastically. It would basically change the spring rate.
from what I understand about torsion bars this is correct as they are very linear, hence the need for jounce bumpers.
Old May 4, 2006 | 05:48 PM
  #22
moregrip's Avatar
what a rush!
Originally Posted by SS_bnoon_SS
Correct, the ride height is changed more by the "porkchop", the torsion bar keys, and the adjustment bolt more than it is the spring.
I want to go to heavier bars, but will still keep the low ride height of my lowered SS (plus I will be adding heavier sways and end links). I like the fact that you posted the part numbers and rates!
what is the stock SSS torsion bar code? that might actually be the best match as the weight between the two trucks is within 100lbs I believe.
Old May 5, 2006 | 12:12 AM
  #23
moregrip's Avatar
what a rush!
as long as they will fit the keys looks like the YT's or WZ's might be the best bet
15712411-LH (code WZ) (Max torque 7267)
15712412-RH (code WZ) (Max torque 7267)
15072933-LH (code YT) (Max torque 7267)
15072934-RH (code YT) (Max torque 7267)
Old May 5, 2006 | 09:08 AM
  #24
SS_bnoon_SS's Avatar
If I can get some time this weekend, I'll crawl under and check. Where are they tagged?
Old May 5, 2006 | 09:47 AM
  #25
moregrip's Avatar
what a rush!
near the back end of the torsion bar, close to where it inserts into the key, thank you
Old May 8, 2006 | 09:37 AM
  #26
04BlackGmc's Avatar
10 Second Club
YH my man!
Old May 8, 2006 | 05:26 PM
  #27
moregrip's Avatar
what a rush!
Originally Posted by 04BlackGmc
YH my man!
15058267-LH (code YH) (Max torque 5913)
15058268-RH (code YH) (Max torque 5913)
wow! 2 questions, what model/buildout is your truck, and B, how is the ride?
I need another member to conform the SS AWD torsion bar, any help?
Old May 8, 2006 | 10:24 PM
  #28
04BlackGmc's Avatar
10 Second Club
2004 GMC sierra 1/2 4wd... It rode awsome from the factory, but now kinda stiff since its cranked 2-3 inches.
Old May 8, 2006 | 10:30 PM
  #29
moregrip's Avatar
what a rush!
EC or RC?
Old May 8, 2006 | 10:31 PM
  #30
04BlackGmc's Avatar
10 Second Club
Rclb.
