Torque Converter Failure?
Old Mar 28, 2016 | 09:46 AM
Aboss's Avatar
Default Torque Converter Failure?
Hey guys, just recently finished my lq9 swap. Still running the stock 4l60e but with a 3600 rpm precision vigilante (3rd and 4th were gone in the first 10 miles) first and second seem to still be strong from driving in the neighborhood and up the street. well this morning i drove up the street to the corner store (maybe a mile) and at about 5k rpm it sounded like my y pipe was slipping off the header, i look back and see smoke so i whip back to the house and look up under the truck and see trans fluid coming out of the bellhousing. Im assuming it was my torque converter failing? trans had plenty of fluid before leaving the house? anyway plans are to restall to 3200, stall speed did not need to be 3600 like my shop recommended and a built 4l60 because the truck is a 99 and the i dont wanna f** with the harness anymore.
Old Mar 28, 2016 | 02:16 PM
tgui's Avatar
You sure you didn't pop a trans cooler line?
Old Mar 29, 2016 | 03:03 AM
BlueTexan24's Avatar
I'm thinking a line broke as well. Or maybe the converter wasn't seated all the way on the input shaft. It would take a lot more power than that to crack that converter if installed properly I would hope.
Old Mar 29, 2016 | 05:20 AM
madmann26's Avatar
Cooler line or worse,
Sounds like you broke something.
Old Mar 29, 2016 | 06:44 AM
tgui's Avatar
There is an oring around the input shaft right? Doesn't the converter seal against that?
FlowmasterMufflers
Nov 26, 2016 10:13 PM
Ferocity02
Feb 22, 2016 12:28 PM
Shanewabindato
Feb 16, 2016 12:17 PM
Slow91z
20
Feb 15, 2016 03:51 PM
Slowchevy06
Jan 21, 2016 08:56 PM
