Tired of the GM lean!
Old Apr 19, 2007 | 05:51 AM
  #21
beastmode's Avatar
Import Moderator
Originally Posted by Keith
Going from the front: The battery(~35lbs), You(171lbs average) and at least 26 gallons(156lbs) of gas are on the passenger side.
id say the exhaust probably cancels out the battery... but i never realized that they was actually that much weight there
i cant even notice it on my truck, i think some of you guys are to damn picky
Old Apr 19, 2007 | 06:37 AM
  #22
04GIBBS's Avatar
Yes sir I am picky but I hate the 3/4 inch difference in my suspension.
Old Apr 19, 2007 | 07:22 AM
  #23
Colby 04's Avatar
Originally Posted by CHEVRACER83
Subject: Vehicle Lean - Left Front Sits Low or Right Rear High (Add Spacer Between Left Rear Spring Pack and Axle) #06-03-06-005A - (01/12/2007)
Models: 1999-2007 Chevrolet Silverado (Classic) 1500 (½ Ton) Series
1999-2007 GMC Sierra (Classic) 1500 (½ Ton) Series
with Two-Wheel Drive
This bulletin is being revised to update the models to reflect that bulletin only applies to 1500 (½ Ton) Series. Please discard Corporate Bulletin Number 06-03-06-005 (Section 03 -- Suspension).
Condition
Some customers may comment that their vehicle appears to lean. In most cases, the vehicle will sit low left front or high right rear.
Correction
Measure fender wheel-opening heights, front and rear, to quantify vehicle lean. Fender wheel-opening heights are related to, but distinct from, trim height (a.k.a. Z and D height). The front wheel-opening height is known as P height, and the rear wheel-opening height is know as R height. The P and R heights are not set at the factory, nor is a specification given for them. However, they are the most direct and repeatable measurement of what a customer would see as the vehicle leaning. Perform the following before measuring the fender wheel-opening heights:
• Make sure the vehicle is on a level surface, such as an alignment rack.
• Set the tire pressures to the pressure shown on the certification label. Refer to Label - Vehicle Certification in General Information.
• Check the fuel level. Add additional weight if necessary to simulate a full tank.
• To ensure proper weight distribution, make sure the rear storage compartment is empty.
• Close the doors and hood.
P Height and R Height Measurements
P height and R height are measured the same way. They are the distance from the ground to the highest point on their respective wheel-opening, going through the center of their respective wheel. Record the measurement on the repair order.
If the difference from left to right for P and R height is 15 mm (0.59 in) or less, no repairs are suggested as the vehicle is within specification. If the difference exceeds 15 mm (0.59 in) for either measurement, install the spring spacer to the left rear side of the vehicle following the procedure below.
Raise and support the vehicle.
Support the rear axle.
Remove the U-bolt nuts, remove the U-bolts and anchor plate. Discard the U-bolts. DO NOT discard the nuts or anchor plate.
Remove the lower shock nut and bolt.
Raise the vehicle or lower the axle enough to allow for installation of the spacer. Install the spacer, P/N 15872657.
Lower the vehicle or raise the axle.
Install the lower shock nut and bolt.
Tighten
Tighten to 95 N·m (70 lb ft).
Install the anchor plate, new longer U-bolts, P/N 15872655, and nuts.
Tighten
Tighten the nuts to 72 N·m (53 lb ft).
Remove the axle support and lower the vehicle.
Re-check the P and R heights in the previous location. Record these readings on the repair order.
After all measurements are done, perform a road test and check headlight aim.
If these steps do not resolve the condition, please contact GM TAC for further diagnostic assistance.
Parts Information
Part Number
Description
Qty
15872655
Rear Spring Spacer
Rear Spring U-Bolt
Good information...looks just like the post I put up the other day for another chevy lean thread
Old Apr 19, 2007 | 02:52 PM
  #24
Keith's Avatar
My truck doesn't do it, so I never cared. My dad's leans though.
Old Apr 20, 2007 | 12:24 PM
  #25
jus1975's Avatar
What if you have a VHO with torsion bar front suspension. I have tried everything to level the front and rear. I've tried cutting the bump stops different lengths and I have some air shocks on the rear. Nothing seems to work.
Old Apr 20, 2007 | 12:37 PM
  #26
TexCrew's Avatar
you should post some pics. is it really that bad?
Old Apr 20, 2007 | 12:54 PM
  #27
WhiteChevy3's Avatar
mine is bad also! from 1/2in to 1in (depending on how much gas) just recently i moved my RR shackle to the top hole to fix this (had been running just 1in drop) and it still leans!! im thinking of makeing some sort of spring rubber to level it further, or putting my stock shackle on the left rear!
Old Apr 22, 2007 | 01:22 AM
  #28
4.8bowtie's Avatar
has anyone tried decranking the passenger side torsion bars on a 4x4. sounds like it should work and hopefully the rear will follow the drop.
Old Apr 22, 2007 | 01:24 AM
  #29
trever1t's Avatar
2nd fastest 5.3 ECSB
This is what I want to know.
Old Apr 26, 2007 | 10:31 PM
  #30
jgun's Avatar
The adj. shackels are made by AIM, just look in a TRUCKIN book and bet there number, i heard they stopped making them due to breaking under a heavy load. I have them on my truck and they go up to 5" of drop. My bed is cut out for them to come up through, but i got a body shop to cover the holes. Up front i just cut my pass. side about 3/4" and now my truck sets like it should!!
