Time to crack open my 4l60
Old Feb 14, 2008 | 12:35 PM
  #21
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Originally Posted by shakinlm7
The pics are pretty big so here's a link to them.
Seems like you're good to go. Do what you planned, and stash away some EXTRA for when you putt the turbo on. Not wishing bad luck, but even I would have FLT or Performabuilt build you a unit from the ground up to hold for FI.
Good luck!
Old Feb 14, 2008 | 08:49 PM
  #22
WillPewter2000's Avatar
The gear selector shafts are diferent on the two transmissions. There isn't room to mount your neutral saftey switch on the f body tranny.
Old Feb 15, 2008 | 07:24 AM
  #23
95ImpSS's Avatar
Is that a fact? Don't recall, but would like to know...
Old Feb 15, 2008 | 07:57 AM
  #24
moes04silverado's Avatar
Originally Posted by KySilverado
It is much easier to install the servo's and kit with the trans out of the vehicle. Take pictures when you are taking it apart. You will get confused on a lot of things. Trust me. Pay attention to bolts and length in the valve body. All the check ball locations. When working on the valve body only do one thing at a time and have everything ready and in line to go right back in.
I agree but with thsoe 4l60e rebuild manuals he should be ok. I used the blue manual and had no problem at all. If he has any sorta mechanic ability he will be ok.
And the servo is definatly easier to install with the tranny out!!
Last thing be sure you dont lose the steel ***** when you remove the valve body and be sure they are in the right places when you put it all back together.
other than those few tips I thought it was a pretty easy project.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
Dan Neumann
11
Aug 7, 2022 09:06 AM
DrX
Aug 19, 2015 04:45 PM
lo&sloSierra
Jul 19, 2015 10:56 AM
GM1697
Jul 9, 2015 01:55 PM
