is is there a trick to get the servo cover off!!!!!!
Old Mar 8, 2008 | 01:50 PM
cmiller's Avatar
Default is is there a trick to get the servo cover off!!!!!!
yes i took the snap ring off
i got pliers on the over trying to pull it off, ive hit the plies with a hammer trying to get it off and its not giving
need help fast
thanks chris
Old Mar 8, 2008 | 02:07 PM
sbw9056's Avatar
There is an "O" ring on the cover that you have to cut. Just pull it below the slot and cut it.
http://s-series.org/component/option...m,6/task,item/
Old Mar 8, 2008 | 02:45 PM
nonnieselman's Avatar
or you can put some pliers on it and use a screwdriver right below the servo cover and use it as a pivot point to get some leverage and it will pop off. or you can just cut the o-ring and pull the o-ring out and the cover comes off with your hand..
its easy to do.
Old Mar 8, 2008 | 07:55 PM
cmiller's Avatar
cutting the o ring did the trick
thanks chris
Old Mar 8, 2008 | 09:20 PM
Truckshop's Avatar
if you pull on the oring with a pick you don't have to cut it. just stretch it and then reuse it.
Old Mar 9, 2008 | 09:02 AM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Done that a couple of times w/o damaging the o-ring.
Old Mar 9, 2008 | 09:52 AM
TXsilverado's Avatar
a pry bar works for me...theres a notch in the side that you can get to and it will pop right out. then you can reuse the 0-ring.
lxcoupe
Sep 6, 2017 08:24 AM
Tigger Welder
Oct 1, 2015 08:41 AM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
TrickTurbo
Sep 23, 2015 08:41 PM
cousblake11
Sep 9, 2015 06:52 PM
