Is there such thing as a 1inch drop shackle?
Tin Foil Hat Wearin' Fool
Or you could just use a 1 inch drop shackle and leave the lift blocks in would be the same thing.
I look into the daystars then cause I have heard people bitching about thier shackles squeeking.
Works if you want to go lower later too!
Mine sqeeked even with the zerk fittings well lubed but after a little investigation I found out it was because I tightened them to tight. I loosened them 1/8-1/4 turn each and the sqeeking went away.
NOt really untill you get up in the 4-6 inch range when you start having BAD axle wrap problems with any decent amount of power. Then you need ladder/ traciton bars. The 1.5 inch stockers arent that big a deal. I know what oyu mean about the bandaid but they also make the truck ride better since there isnt a need to arch the springs more for the lift.
hey, Cody I think you can get the shackles in a place down Spencer Hwy.. for $45.. pm me if you want... they do too have the 2 holes for 1" or 2"... and they have that grease fitting too... mine have not squeeked and I havent even greased them yet!!!?/???
maxspeed05V
Nov 11, 2015 04:20 PM
shupe
Aug 5, 2015 06:45 PM
signguy62
Jul 27, 2015 03:42 PM
