Th400 swap, converter clearance??
Old Oct 26, 2021 | 01:39 PM
BoostedNNBS's Avatar
Default Th400 swap, converter clearance??
So I did a th400 swap on my 08 NNBS, when bolting up the torque converter it left this much space between the pump housing. Is this normal? First th400 swap so I don’t have anything to reference. I’m taking the torque converter bolts off now to clearance the mounting surface to the flexplate. I’m finishing up the swap and now I’m second guessing everything lol. Does anyone have a picture of a properly seated torque converter and how much it sits outside the pump housing? I heard the 3 clicks when installing it but I’m unsure if it came out when getting it in the truck!
Old Oct 26, 2021 | 01:59 PM
RedXray's Avatar
100% Redneck
You need to seat the converter into the transmission all the way back until it bottoms out. Then check the clearance between the converter and flex plate. My Circle-D converter instructions say you need 1/8" converter to flex plate clearance (+/- .0025")
Did you use a special swap flex plate for the non LS transmission swap?
https://www.circledspecialties.com/installation-tips
Old Oct 26, 2021 | 02:07 PM
i fully seated the converter into the trans before I installed the trans. I heard it bottom out then I installed it in the truck, the only thing I didn’t do was clearance the flexplate to the converter mounting pads, which I’m doing now. If I had to guess, by eye it looked like a lot more clearance than 1/8. I used the flexplate that came in the vans. Supposed to be perfect for LS to th400.
Old Oct 26, 2021 | 02:27 PM
RedXray's Avatar
100% Redneck
White the proper converter clearance it keeps the converter drive engaged deep enough into the transmission pump without bottoming out and damaging the pump. You can use washers to space out extra clearance (unless it's excessive) which should be easy with the TH400. The 4L60's are a pain to space because of the full bellhousing. You have to work through the starter hole for each bolt & washer. Post back you clearances for other members looking for future reference.
Old Oct 28, 2021 | 08:14 AM
Just an update, I removed the torque converter bolts and measured the clearance, 1/8 fit between no problem, 3/16 fit if I shoved it in there but realistically I’d assume 5/32 would be the biggest that would fit. Shim it to get it down to 1/8??
Old Oct 28, 2021 | 09:28 AM
MaroonMonsterLS1's Avatar
no
if it is above 1/8 and below 3/16 just leve it as-is
be sure the pilot is engaged
Old Oct 28, 2021 | 09:32 AM
Originally Posted by MaroonMonsterLS1
no
Thank you! I guess I just took the bolts out and measured for peace of mind lol, turns out it was just fine 🤷‍♂️
probuilder1
Jan 24, 2011 06:28 PM
03GMC
Apr 11, 2008 06:43 PM
black4x4
Dec 16, 2005 11:55 PM
6.0vette
Dec 16, 2004 09:37 AM
GoldenVelvet
Feb 19, 2003 08:23 PM
