TBSS 9.5 rear end rebuild
Old Aug 20, 2013 | 05:20 PM
Silver6sp's Avatar
12 Second Club
Default TBSS 9.5 rear end rebuild
2007 TBSS 14bolt 9.5 rear end. Very noisey, Im replacing the pinion bearings and carrier bearings. All parts installed and i cannot get a backlash. I reused the pinion shim and carrier shim. All the parts are correct and the races are seated properly. I have reinstalled everything 4 fours, still no backlash and we I torque the carrier bolts, the diff becomes difficult to turn.
Thanks in advance!
antonio
Old Aug 20, 2013 | 07:03 PM
brandon6.0's Avatar
Did u pull or seat the pinion bearing all the way down. New crush sleeve?
Old Aug 20, 2013 | 07:27 PM
Silver6sp's Avatar
12 Second Club
yes and yes
Old Aug 29, 2013 | 09:16 PM
1FastBrick's Avatar
Custm2500's Rude Friend
I am hoping you got this fixed already.
If not, it sounds like you need to adjust the side clearance.
Not all bearings are manufactured the same and you may need to offset the carrier with some thicker shims.
Old Aug 29, 2013 | 09:45 PM
Beatdown Z's Avatar
Laid Back
Did you install the carrier bearing shims on the wrong sides? They're usually different thicknesses.
pjb1972
Sep 17, 2015 02:06 PM
vipergtrdj
Aug 6, 2015 10:19 PM
shupe
Aug 5, 2015 06:45 PM
Ketis
Jul 23, 2015 12:37 PM
