TA Girdle installed w/ pic
Originally Posted by krambo
Nice. I have the same one. I have the stud kit and need to remove it and install. You have to specify that you have the metric bolts,...I believe all 2000 and up have the metric. I do.
Did you use any additive in the rear oil or not? I didn't and all is fine,...just mobil 1 synthetic. I hear different opinions.
I did use the additive in mine, but only standard gear oil was used.
Looks good, I have the same one myself...it came with a note in reference to what size bolts were needed to install it. I ended up hitting 2 Home Depots and 1 Lowes to get 9 of 10 of the bolts, then used a six point for the bolt that secures the brake cable (ran out of local places to find the 10th bolt and wanted to get it done lol). Just a little info about what I experienced: mine started leaking past the threads of the pre-load bolts, so I backed them out and put some teflon around the threads and re-torqued them. Shortly after, the gasket (which was supplied with the cover) blew out on both sides where there are holes in the rear end housing to supply gear oil to the carrier bearings. I replaced the gasket with a factory one, and it has been fine ever since. (I checked the vent for the rear diff to make sure it wasn't clogged and it was OK). If you look at the TA gasket vs. the factory gasket, the TA gasket has 2 small slits to accomodate the supply of gear oil to the carrier bearings, while the factory one just goes around those holes so they're completely exposed...this may have something to do with why mine blew. Not sure if anyone else had the same experience. Here's a pic of mine shortly after I installed it (those tail pipes have since been removed, shocks changed to Bilsteins, and truck has been lowered).
p.s.- I didn't do the stud kit, but will eventually if and when my G80 goes kaboom and I go for an Eaton, or other brand posi unit
where is everyone buying these covers i was plannning on replacing mine since i wanted to change the fluid and its leaking!! im pretty sure i can figure out where snakeoiler got his!
also quik did you go with the full floaitng 14 bolt rear end(8lug) or did you just get the 14 bolt with 6 lugs?
