t-56 swap
Old Nov 4, 2011 | 06:20 PM
  #31
Boosted_Silverado's Avatar
Updates if anyone cares???
ordered 04 5 speed crossmember, quicktime bellhousing and spec stage 3+ clutch with spec flywheel.
Old Nov 5, 2011 | 07:33 AM
  #32
I am sure someone cares... Looking at peicing a t-56 swap together myself. Can you take a pic of the master cylinder going through the firewall from inside the truck?
Good luck on the swap.
Old Nov 5, 2011 | 07:35 AM
  #33
1979rs/z28's Avatar
12 Second Club
I care! I have a 5speed at the moment and id like to see what it takes to make that crossmember work. Good work with the swap so far
Old Nov 5, 2011 | 05:26 PM
  #34
BadAssChevy327's Avatar
been debating on going with this again. should have just bit the bullet last time before the 80e
Old Nov 10, 2011 | 08:41 PM
  #35
Crossmember came in today.
Old Nov 11, 2011 | 06:57 PM
  #36
cfaluck13's Avatar
so the t56 will bolt right up to the 5-speed crossmember? Im starting to regret ordering the parts to rebuild the 60e, and clean truck to man!
Old Nov 15, 2011 | 02:22 PM
  #37
from what i have seen it works, im using a t-56 magnum so i might have to mod it abit.
spec 3+ clutch came in today
Old Nov 25, 2011 | 06:32 PM
  #38
Bellhousing showed up today
Old Nov 25, 2011 | 08:06 PM
  #39
hog's Avatar
hog
I think you will enjoy that clutch, and its 967 lb/ft torque rating. Its their most expensive single disk.
Their most expensive super twin disk is $1900 with a 1795 lb/ft capacity the least expensive super twin is $1399 with its 900 lb ft rating.
Their mini twin goes for $1649 with a800 lb/ft rating and their triple disc mini costs $1799 with a1200 lb/ft rating.
Let us know how the clutch works, cool swap for sure.
peace
Hog
Old Nov 27, 2011 | 02:18 AM
  #40
04Burban's Avatar
I'm watching since I'm thinking on swapping my 5.3 into my Monte Carlo with a T56...
