Swap Need info
Old Jul 24, 2007 | 02:55 PM
383sst's Avatar
Registered User
Default Swap Need info
OK Ive got a 2007 classic 2wd, short bed, 4.3 V6, 5-speed, with 3.23 gears. My question is wheter or not this tranny will bolt up to a 5.3. Any help is appreciated.
Old Jul 25, 2007 | 03:32 PM
383sst's Avatar
Registered User
anyone
Old Jul 25, 2007 | 04:04 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Do you know the model of the tranny?
A way to look at it in reverse would be to check with GM if a 4L60E can be bolted to the engine or if it uses a different automatic. I'd think the major roadblock would be in the bell bolt pattern followed by a clutch that will fit the tranny and the 5.3 flywheel.
Wish I could help.
Old Jul 25, 2007 | 04:20 PM
ZZebes's Avatar
a T56 would be a better swap, that 5 speed wont hold behind a 5.3L
find a junkyard T-56 and go from there
Old Jul 27, 2007 | 09:20 PM
my black ss's Avatar
Default tranny swap
Yeah it will bolt up and should last fine if you dont speed shift it day in day out ....Just use what you have now and when it pops then do the t56 swap.And a tip would be to do any motor upgrades cam heads and so on before you install the motor...Or even better buy a pre modded motor from someone on here doing a 6.0 swap
Bumpers
Aug 4, 2024 09:44 PM
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
OHsixLS3
Aug 10, 2015 07:19 PM
05GMC4.8
Aug 7, 2015 09:55 PM
gtyler04
Jul 28, 2015 06:21 PM
