suspension help, what am I doing wrong.
Old Jan 2, 2011 | 05:19 PM
  #21
LS1TRUCKGUY's Avatar
Originally Posted by tarinitup
Good news. Mhotrodscooter came over today and found that passenger tire is 1/2" further front than drivers which explains the drifting. Also bought the flip kit caltrac perches from bluecajun5.3 and should have the flip kit installed by 00z71 pretty soon. Don't know how it shifted but it shouldn't be hard to fix and rear will be loose for flip kit anyhow.
how do you plan on fixing this since the axle perch sits on an alignment pin, and isnt adjustable?
i just went and measured mine and i have the same problem. but mine is about 1/4" off...
Old Jan 2, 2011 | 05:20 PM
  #22
that question was actually for tarinitup but its good to see how others are making it work. looks like we do it about the same.
i set my shocks to 7 on the ranchos. touch both bars to the leaf spring while sitting in the truck, then turn the bars. i crank the preload much farther than calvert recommends though. i start at 1/2 turn on passenger side and 3/4 turn on the drivers side. if it doesnt hook, i give it another 1/4 turn on each side. dead hooked 1.68 N/A last time and havent tried on the spray yet...but now i have an entire new suspension setup to learn
care to elaborate on the new setup?
Old Jan 2, 2011 | 10:18 PM
  #23
TXsilverado's Avatar
https://www.performancetrucks.net/fo...d.php?t=464466
Old Jan 3, 2011 | 09:52 AM
  #24
mhotrodscooter's Avatar
How did you get the measurements? Being a 1/4'' off ain't bad. Not unless your trying to run 9's. Every bolt on the suspension has play. So you have to move it around till you get within a 1/16 or 1/8 or dead on.
Old Jan 3, 2011 | 04:38 PM
  #25
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
i think i was the first one to say something to the OP about something being tweaked from his videos.... glad you figured it out!
Old Jan 14, 2011 | 11:37 PM
  #26
tarinitup's Avatar
9 Second Truck Club
Me and 00z71 got the new flip kit installed today and difference was night and day. The ride improved so much and also stopped trying to go sideways all the time. Thanks for the advice on flipkit and going back to stock hangers. I got it to hook now from a 50 roll on 7 psi and it feels great.
Old Jan 14, 2011 | 11:42 PM
  #27
So y'all was able to get everything straight? Did y'all find out why it was so far off?
Old Jan 14, 2011 | 11:51 PM
  #28
tarinitup's Avatar
9 Second Truck Club
We think it was caused by thinner bolts when I had hangers installed.
Old Jan 15, 2011 | 12:18 AM
  #29
Good too hear it's was that & not a bent axle tube..
Old Jan 15, 2011 | 12:42 AM
  #30
AKlowriderZ71's Avatar
11 Second Hall Moniter
Glad to help, glad it is working much better now.
When are you going to the track next? Waiting for some results!!
