Stupid Shackle Question Here
Old Aug 6, 2018 | 10:56 PM
matslp488's Avatar
Default Stupid Shackle Question Here
I got some new lowering 6400 Belltech shackles sitting in my garage that I planned on installing some time ago, now I’m thinking of doing a flip kit instead for the rear... looking for a 5” drop instead of the whole 6” a flip kit gets you.. can I use these drop shackles as a 1” lift shackle?? They have 5 holes for adjusting the height... Or would I be better off getting a regular 1” lift shackle?? Thanks! Btw truck is an 05 ext cab
Old Aug 7, 2018 | 05:16 AM
madmann26's Avatar
You need a 1in lift shackle. If you try and use the shackle you have you'll drop it even more.
I would recommend a c-notch. It's really not that hard if you have a sawzall and a cutoff wheel with spare discs.
Old Aug 7, 2018 | 07:19 AM
MrHorsepowerLSx's Avatar
11 Second Club
I’m just about 5” rear drop on my truck. I did front hangers/rear shackles and pulled the overload which is .750” thick
And a c-notch is a must
Old Aug 7, 2018 | 07:35 AM
matslp488's Avatar
Notch Is also in the plans... I know the shackle will drop it more IF I use the top 2 holes (Belltech shackles have 5 holes for adjustablilty).. but I’m wondering if I can use the bottom 2 holes to lift it 1in... don’t wanna really use hangers cuz they’re a pita and if I decide to go back to stock or lower I can just adjust/remove the flip kit
Old Aug 7, 2018 | 07:37 AM
matslp488's Avatar
Old Aug 7, 2018 | 11:49 AM
11 Second Club
You won’t be able to ever use the first 3 holes as they are tapered inward. The leaf spring eyelet would never fit, so you are limited to the top 2 holes. You could make the third hole work if you cut a relief into the top bracket on one side of the shackle and stretched it over the spring eye........... but I wouldn’t do that as you will loose strength in the shackle
Old Aug 7, 2018 | 11:13 PM
matslp488's Avatar
I think I would just be better buying a set of lift shackles and selling the belltechs... a guy locally is selling some adjustable ones for $25... stock position and 1” lift... but they’re for an 01 f150... any advise if they’ll fit?? They’re for 2.5 leafs
Old Aug 7, 2018 | 11:37 PM
FFDP's Avatar
Get the ones designed as a 1in lift shackle for these trucks, don't make it harder on yourself.
dlt76028
Apr 3, 2011 07:58 PM
Closer_2001
Nov 28, 2010 10:54 AM
BLK WDO
May 7, 2009 06:17 AM
1BADHD
Dec 2, 2003 01:07 PM
