Stock driveshaft strength
Old 03-20-2017, 09:37 PM
bbowerman's Avatar
Originally Posted by Jeebalow
When it comes to driveshaft it's not about how much power it can hold, it's about what the critical speed or shaft rpm is. You may never have enough torque to twist the stock shaft and destroy it on takeoff, but get up to over 100 or 120 MPH and that same shaft will destroy itself. Once you get to a vehicle speed that makes the shaft get to it's critical speed, it will start looking like a jump rope and then say goodbye to it and maybe your transmission and floor.
I went with a shaft from driveshaft specialist in texas. It's a 2 piece steel shaft with 3.5" OD and 1350 joints. Talk to them and tell them what you have and what you want to do with it. I asked for a shaft that can handle 8000 shaft rpm, even though I will likely never get there, due to my gearing and tire size combo. (4.88 and about 29"). They did the calcs and decided to go 2 pieve steel rather than one piece aluminum due to the length. This is in a 95 extended cab short bed truck.
nice to know what did that run you if you don't mind me asking. Truck is fixing to be turbo so I am trying to iron out the weak spots.
Old 03-20-2017, 09:38 PM
stealthperf's Avatar
For what it's worth, I have a buddy running a ccsb 4x4 duramax twin turbo with the stock aluminum rear drive shaft.. I'm not recommending it or saying it's safe but he has been 11.30s at 120+.
Old 03-20-2017, 10:55 PM
Jeebalow's Avatar
$680 for the shaft, $120 for a chromoly yoke, $70 for shipping.
Here are some more specs:
3.50"x.065"Front & 3.50"x.083" Rear New Design 2pc Driveshaft System. Spicer XL U-Joints (1350), Super Duty Carrier Bearing.
