Steering Wobble-Fixed
Old Aug 26, 2006 | 03:43 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Default Steering Wobble-Fixed
Regardless of what I was told about the steering shaft lube defect fixed for 2005 GMC/Chevy trucks, GM has issued a "kit" to fix the issue for the non-existant issue!
They pulled the steering shaft, and did whatever they did, but now my truck steering feels like it should, not like some Yugo!
Old Aug 26, 2006 | 04:42 PM
BlackLM7's Avatar
Yeah, I need to get my steering wheel wobble fixed too. It's really annoying.
Old Aug 26, 2006 | 06:28 PM
budhayes3's Avatar
PT's Slowest Truck
Yea, the lube kit cures the knocking you get in the steering wheel...I've done mine once already after having the steering shaft replaced under warranty. So far it's been a few years and it's stayed quiet...I think I'm just starting to to get an occasional knock from time to time. PN for the lube kit is 26098419. It costs anywhere from about $8.50 to $12.00, depending on where you go and what kind of a discount you can get.
I bought a few kits to keep "in stock". When I did my friend's truck a few weeks back, his was knocking real bad, and I actually used 2 kits to fix him up.
Old Aug 26, 2006 | 11:55 PM
Holy crap I just thought it was because my truck was lowered. Mine is horrible. How does this kit work???
Old Aug 27, 2006 | 12:43 AM
budhayes3's Avatar
PT's Slowest Truck
It's real simple...it comes with a syringe with grease, and a plug to cork off the end of the steering shaft. Basically, you reomove the intermediate steering shaft (one bolt under the dash, one under the hood), remove a clip from one end of the shaft and squeeze the grease into it. Then you install the rubber "cork" and work the shaft in and out a few times to spread the grease on the splines. After that, it's just matter of removing the cork, re-installing the clip, and bolting the shaft back in. Takes about 15 minutes at an easy pace...piece of cake.
What it actually does is to fill the clearance between the two splined parts of the intermediate shaft with grease, so the shaft has less play and doesn't bang against itself.
Old Aug 27, 2006 | 01:28 AM
blue 01's Avatar
Here is a right up on how to.
link
Old Aug 27, 2006 | 06:36 AM
TIM Z's Avatar
11 sec. Truck Mod
this sounds like a ford problem! we shouldnt have this on our trucks. I had my shaft completely replaced, but my friend went in and they wont replace them any more, they just greased it, at least it's documented.
Old Aug 27, 2006 | 08:41 AM
trever1t's Avatar
The sad part is that I complained about it over two months ago and was told there was no issue.....then yesterday there was a 'fix'!
Oh well, at least it's better now!
Old Aug 28, 2006 | 11:30 PM
NeverSatisfied02's Avatar
I need to have mine done. I already had it in at the dealer and they said they did their inspection but "no problem". Ill be taking it back and rasing hell till they fix it for me!
Old Aug 29, 2006 | 05:55 AM
trever1t's Avatar
Yeah, I know. Last time i complained they had two techs take it for a ride and they didn't feel anything. 1month later they have a fix for it!
