Steering Stabilizers - Feels Slopy
Old Aug 11, 2005 | 03:31 PM
1TRUESS's Avatar
Default Steering Stabilizers - Feels Slopy
Anyone else's truck drive all over the place? When I break it always goes left or right. Feels like I have that 70s POWER steering. Truck wonders all over the road, even at cruising speeds. Can I tightin up the steering at all?
Old Aug 11, 2005 | 06:49 PM
Zick's Avatar
Dumb question, but have you had the alignment checked?
My truck used to get blown all over the road just by the wind, it ended up being my alignment out of whack. Funny thing is that it still drove straight as an arrow.
Old Aug 11, 2005 | 07:09 PM
budhayes3's Avatar
PT's Slowest Truck
Assuming tire pressures are all OK, you might have a loose steering or suspension component? (ie: tie rod end, ball joint, wheel bearing, etc)
Old Aug 11, 2005 | 07:35 PM
KySilverado's Avatar
Worst case I had was in my last vehicle. A 4runner. Followed every groove in the road, wind blew it everywhere. Good alignment fixed it.
Old Aug 11, 2005 | 08:36 PM
Zick's Avatar
Glad to see I'm not the only one with this problem.
Old Aug 11, 2005 | 08:38 PM
99Silver6.0's Avatar
Check the lower ball joints. Mine are FUBAR'ed.
Old Aug 12, 2005 | 12:54 PM
Some good points. If it is a high milegae vehicle look for worn components. Idler arm, ball joints, tie rod ends. If newer/lower mileage lean more toward alignment.
Old Aug 12, 2005 | 04:35 PM
jerome's Avatar
as for braking and it veering off to the side, that may be indication of need of brake job
Old Aug 12, 2005 | 04:58 PM
1TRUESS's Avatar
I guess i will check all of this next week when I go on vacation. Thanks, I will let you all know what I find out.
Old Aug 12, 2005 | 05:00 PM
1TRUESS's Avatar
Any tricks or hints on what to look for or how to check all of the above?
