Stall Advice - TVS2300 Daily Driver
Hey guys wondering if I could get some stall advice for a 4L80e DD that won't see the track and wants a balanced combo on the street that is quick and responsive, but not too violent off idle so I can never put the power to the ground.
The combo will be a 4200lb 2wd truck, 6.2, TVS2300 at 6psi stock pulley, 91 octane, no meth, small custom cam, headers, 3.73s, 275/60/15 street tires (maybe one day I'll run a 275/60/15 drag radial). I was thinking even of using a stock 4L80e 4.3/5.7 gas motor converter which is supposedly a ~2500 stall? If I'm never going to see the track then why use a converter that will significantly hurt my ability to put the power down off idle? I was also considering a Circle D 278mm 2600-2800 stall or even some of the Hughes 2400, Chevrolet Performance, or TCI 2400 stalls. Any thoughts I'd love to hear them!
I always remember that the CTS-V LSA guys pretty much always use a stock converter.
The 278mm converters are pretty inefficient with any real power unfortunately... You will most likely need a step up to a billet unit.
The CTS converter is a touch looser than most stock stuff, but its large diameter and still very efficient up top. It wont work with the 4L80e unfortunately.
In such a light truck I think a single disk is fine. I would probably go with a 258mm thats built 2800ish. You will flash it higher than that, but it will be great up top.
