squeel when fully locked?
Old Aug 21, 2006 | 11:27 AM
Default squeel when fully locked?
when I turn the wheel to full lock, and turn my tires squeell across the ground. (mcgaughys spindles) normal or need an alingment?
Old Aug 21, 2006 | 11:13 PM
budhayes3's Avatar
PT's Slowest Truck
If you did the spindles and didn't have an alignment, it should be aligned anyway. It may or may not help the squeal though. When I dropped my truck via keys, my camber went -1.5 on both sides and it was toed way out.
Old Aug 22, 2006 | 12:31 AM
LS1TRUCKGUY's Avatar
it will squeal a little bit at full lock. the geometry is off with the angle of the tie rods, causeing different movement between the two front tires. mine does it too, even after having it aligned, but im not running the mcgaughy spindles.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
Alco
Jul 20, 2016 04:53 PM
bearden86
26
Nov 15, 2015 03:58 PM
dsbodley
Nov 14, 2015 09:46 PM
Cammed4ever
Sep 30, 2015 03:38 PM
