Sourcing Brake/Clutch switch?
Old May 3, 2009 | 11:32 AM
2001CamaroGuy's Avatar
Default Sourcing Brake/Clutch switch?
I'm starting to stock up on parts for my T56 swap. One thing I'm doing is constructing a steel clutch pedal/mount in order to use a Wilwood master cylinder.
I'm trying to find a Brake/Clutch switch to use on the clutch pedal. I would like it to be a "Dual Normally Open" (both close/make contact when the switch is pressed) type since I need two circuits for the clutch (one related to cruise, one related to cranking).
If anyone has info on a comparable switch, please let me know.
My alternative (perhaps the best way) is to use a banjo brake switch to signal a relay.
Thanks,
Chris
Old May 3, 2009 | 12:15 PM
Parke10's Avatar
i dont know much about the swap, but is there not a factory one that would do that ? or no?
Old May 3, 2009 | 12:20 PM
not that I know of right off. the factory "clutch switch" is integrated into the clutch master rod so it is not applicable in my setup.
drummer0415
11
Oct 24, 2015 08:16 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
jtphelps289
Sep 1, 2015 08:58 PM
