Sounds like rod knock - from the trans?
Old 05-09-2011, 11:29 PM
  #21
11 Second Hall Moniter
AKlowriderZ71's Avatar
Using the starter bolts & sliding back the trans works with 4x4's also, just gotta remove both shafts, and more weight sliding the t-case & trans back together. Saves quite a bit of time.
Old 05-10-2011, 02:13 AM
  #22
Mod with training wheels
smokeshow's Avatar
How did those flexplates crack? Quick torque from a blower..?
Old 05-10-2011, 02:35 AM
  #23
Not sure. I've never seen a single broken one on anything LS powered. Only the old small-block stuff. If I had to guess, I'd guess loose bolts..... I'm sure that will **** off alot of guys..... Flame suit on!! Butt-hurt reports are ready to hand out!
Old 05-10-2011, 02:57 AM
  #24
mhotrodscooter's Avatar
All the bolts were tight on the one I replace. The 6.0 was pulled & a 4.8 took it's place 8 months before the flexplate broke. So maybe that GM has a updated version, maybe it has something to do with the design idk
Old 05-10-2011, 07:20 AM
  #25
Glenn98ZM6's Avatar
Mine is 100% stock and has never been off. truck has 156K on it.
Old 05-10-2011, 07:57 AM
  #26
EVILGMC's Avatar
GM did update the flexplate. Look at photos above.
Old 11-03-2011, 05:24 PM
  #27
Glenn98ZM6's Avatar
I replaced this flexplate back in June or so w/ the suggested GM part.
It cracked again. Less than 5000 miles or there abouts.
What are my non-OEM options.
Truck is stock except a mild shift kit for the 1-2 shift, and bumped up line preasure. I tow a large enclosed trailer, so we wanted the shifts quick to save the clutches.
I'm wondering if it is the 1-2 shift that is cracking them. I really don't want to do this again, so I want to be sure I fix it right this time.
Old 11-03-2011, 05:34 PM
  #28
Ouch man that sucks.. Give chris a call @ circle d.. I broke a stock replacement with in two months
Old 11-03-2011, 06:00 PM
  #29
Registered User
Team Paulie's Avatar
I had the same thing happen...TWICE, first one I paid for and the next one the shop that did the job paid for it, Theres some dowel pins they didn't line up or didn't even put back in and the new one cracked in less then a 1000 miles.
I was scared there for a while, but once the tone changed from different loads I narrowed it down.
Old 11-03-2011, 06:05 PM
  #30
TXsilverado's Avatar
i have broken 4 flex plates on my truck.
Quick Reply: Sounds like rod knock - from the trans?
