Soft Shitty Brakes on my 2000 1500 Series
Old Mar 3, 2011 | 12:16 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Hydroboost conversion.
Old Mar 3, 2011 | 12:30 PM
brent5631's Avatar
This is the cheapest and best when compared to new calipers and rotors.
Old Mar 3, 2011 | 12:37 PM
I just ordered a set of Braided lines, going to start with that then I will look at pads then Hydroboost if I am not satisfied! Thanks everyone
Old Mar 3, 2011 | 06:05 PM
oldred95's Avatar
https://www.performancetrucks.net/fo...urban+calipers
If the donor truck is of the same model as the truck its going on then hydroboost is really a pretty easy conversion. On my 95 it was a little more difficult because the booster came from a 2006 which uses a completely different backing plate. The booster was free so it was just a matter of making a backing plate. Fortunately this has been covered already on another site and I was able to find a CAD drawing, print it, trace it, cut it and that was that. Then it was a matter of cutting off the pedal rod on the hydrobooster and the pedal rod on the vacuum booster and threading both, getting it to the right length, then coupling the two together. Then it was the brake pedal swap which is a complete nightmare on a 95. Then it was building up and grinding down the pedal rod until the brake switch worked right. After all that it was well worth it though. It will chomp down on the rotors and lock all four wheels up like its nothing if I need it to.
Old Jan 16, 2012 | 01:38 PM
N/ALS1's Avatar
Bringing the thread from the dead.
Where do you guys get the ss lines for the brakes?
Old Jan 16, 2012 | 08:58 PM
KIFER88's Avatar
I installed a set of braided russel lines from summit racing on my tahoe. they fit great..
Old Jan 16, 2012 | 09:15 PM
mitchellmade's Avatar
MASS seller approved
i did the tahoe / suburban rear loaded calipers ( with bracket) and rotors with stainless lines , major difference wanting to do 05-07 front rotors and calipers (from rear drum brake trucks) 13" rotors but i need to get 17s to do it
Old Jan 30, 2012 | 10:13 PM
oldred95's Avatar
A coworker just did the Suburban rear brake upgrade on his 00 Sierra with 20s on it. He said unloaded he could feel some difference but when he got his car hauler on behind it he could really tell it stopped a lot better.
One of these days I will upgrade to Suburban rear brakes on mine and hydroboost.
SLOPONY
20
Oct 18, 2016 06:05 AM
FlowmasterMufflers
Aug 14, 2015 12:47 PM
kkirwan71
Jul 28, 2015 06:39 PM
FlowmasterMufflers
Jul 9, 2015 11:35 AM
mrgrim
Jul 8, 2015 08:12 AM
