Slip Yoke Axial Clearance
For a 2WD truck with a 2-piece drive shaft, how much axial clearance should there be in the slip yoke? By axial clearance I mean the gap between the slip yoke barrel and whatever the barrel bottoms out on on the trans output shaft.
The slip yoke I bought is too long and I will have to cut it down when I install the 4l80E, so I will have the opportunity to set the appropriate clearance by cutting it a little shorter.
I'm guessing since the first drive shaft is fixed to the frame that not much axial clearance is required... 1/4" maybe? Less, more?
Thanks!
Thanks!
Vortec350ss
01-12-2016 10:36 PM
lukn4trbl355
10-21-2015 11:19 PM
