slight rattle/grinding sound...
Old Nov 7, 2010 | 02:22 AM
smokeshow's Avatar
Mod with training wheels
Default slight rattle/grinding sound...
After I installed the tranny and driveshaft, I get this very intermittent grinding sound. Its not necessarily a rattle, it sounds more like a quick, repetitive grinding sound that only happens for a second, tops. Most times it only happens after I get on it a little bit, and then let off. A split second after I let off and begin to cruise or coast does it make this noise. And it only happens like every 10-ish miles, I can't get it to repeat at will.
I have crawled underneath and shaked/shoved/tapped on everything from the engine back and am still left scratching my head. Ideas?
Old Nov 7, 2010 | 06:04 AM
LS1TRUCKGUY's Avatar
carrier bearing? my dads did the same thing. it was intermittant, and would do it on decel. replaced carrier bearing and noise went away
Old Nov 7, 2010 | 12:12 PM
smokeshow's Avatar
It is the carrier bearing. I looked before but didn't notice. On closer inspection, the dust shield hits a little metal tab when the driveshaft articulates after a release of load. I am going to try to shim it so that goes away.
Skip Fix
22
Jul 9, 2016 07:08 PM
lxcoupe
Oct 4, 2015 08:07 PM
97_ek
Sep 23, 2015 09:16 PM
Jaz
Sep 18, 2015 09:23 PM
ClintBeastwood
11
Sep 13, 2015 11:49 PM
