Slave Cylinder or Master Cylinder?
Old Jan 4, 2012 | 04:18 PM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
Default Slave Cylinder or Master Cylinder?
hey guys....lost clutch pressure this morning...there's fluid in the reservoir & it's not leaking on the ground anywhere....how can i tell if it would be the master cylinder or the slave cylinder? thanks
Old Jan 4, 2012 | 04:41 PM
PathfinderJr's Avatar
Is your master cylinder loose in the engine bay? The master fits into the bracket and then rotates 45* to lock into place, and this is where many break.
These clutch pedal brackets are just weak plastic and after a lot of miles/years/shifts, many give way and you have to end up replacing the clutch pedal assembly and then fab up a metal plate to support the plastic.
Old Jan 4, 2012 | 04:45 PM
OneQwikSS's Avatar
the trucks at my warehouse right now...getting dark & i was getting hungry...i'll check it out tmrw...thanks for the advice though
Old Jan 4, 2012 | 04:59 PM
OneQwikSS's Avatar
also...if it ends up being the slave....can i get away with just changing the slave or if i pull the slave i have to put a new clutch set in as well...thanks
Old Jan 5, 2012 | 12:58 AM
Nah, you don't have to put in a new clutch if you just swap the slave. In fact you don't even have to touch the clutch to swap the slave. Depending on how many miles are on your truck/clutch, it may be worth the peace of mind to you to put in a whole new clutch and slave just so you don't have to get back in there in another 20k miles or something, but that is up to you.
But odds are, especially considering the incredible lack of torque these 4.8's put out, unless you've been abusing the hell outta your clutch, you'll be fine just installing a new slave and calling it a day. If in fact that turns out to be the issue though.
Old Jan 5, 2012 | 07:53 AM
OneQwikSS's Avatar
I have abused the hell out if it...not gonna lie...but the clutch was replaced like 5k miles ago
Tydriver
45
Oct 23, 2015 09:19 PM
91LT16SpeedFormula
Oct 17, 2015 08:01 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
MA$TER_E
Sep 9, 2015 03:14 PM
