Sittin level?
4" in the rear might make it sag too much, but with the same idea in mind as stated above you can install the two inch leaf spring hangers and then install the shackels
but this time using the 1" hole on the shackels.They also do make some 3" shackels that you can buy.
no, the hangers are the things closest to the cab in which the leaf spring connects to, In other words the other mount. The hangers are rivited onto the frame rail. You can purchase them from stylin concepts one of our sponsors. Or anyplace that sells drop kits.
Originally Posted by UBLUZIN03
were can i get spring clamps? Also i read the affect the ride is that true?
since you live in PA i thought maybe you might have a 4x4 truck. if you do, you could always remove the lift block and get some 2wd U-bolts. if you dont have a 4x4, then get hangers.
