Silverado Long Bars?
#31
It's not, they are both exact duplicates made for opposite sides. Bolted in existing holes to located them. Both of those front brackets hang down as far as my front 4 link xmember. This pic u can see maybe a little better. Check my build out, this is no slam bang cobble job. The whole 4 link, bags, crossmember, traction bars etc. It was professionally done. The truck sits within a 1/16th of squareness on the machine. Also drives and steers with one finger. It's rides on the bags with 15psi. Levels out the more weight you add.
#33
#37
8 Second Truck Club
My hd is lifted 7 inches, I had bars made at a fab shop for both sides out of 2 inch dom with rebuild able joints and poly bushings. Also shackles in the front so everything moves with the suspention. I has a set of bars before that were tube and heims, my opinion they sucked and made the rear ride harsh. Another thing done to the rear suspention was a shackle flip, basicly for lifted trucks only. Makes the suspention softer and you can use a smaller lift spring to achieve heigth. Since it's softer air bags were added too.
flatblack83 (03-26-2017)
#38
Thanks..lol.. When the bars were drawn up the program he uses you can also see how they work with the suspention . The longer length and the shackle position means a ton. That all is part of why they are lower on the frame up front and how they are mounted on the axle
