Silverado 2wd to 4wd swap?
Old Jan 12, 2011 | 12:38 PM
RST2uner44's Avatar
Default Silverado 2wd to 4wd swap?
Hey guys I am planning on doing a 2wd to 4wd swap on my 04 silverado and need some help. I plan on getting a transfer case, front diff, axles, and driveshafts from an 04 silverado, unless you guys think that theres is a better route. Also is there any tuning with the ecu that needs to be done?
Old Jan 12, 2011 | 11:44 PM
262_NBS's Avatar
the front frame section is different as well; different bumpstop mounts, steering box instead of rack and pinion and a few other things
Old Jan 13, 2011 | 12:48 AM
02CamaroSSLE's Avatar
yeah you gotta switch from the springs to the torsion bars, also. depending on the condition of your truck it might be cheaper just to get a z71....
Old Jan 13, 2011 | 05:51 AM
Gadgetized's Avatar
Yeah just buy a 4wd.
Old Jan 13, 2011 | 06:01 AM
mhotrodscooter's Avatar
Straight axle could be done.
Old Jan 13, 2011 | 06:13 AM
262_NBS's Avatar
Is it possible to swap a coil spring 2wd truck to torsion bar? aside from having the empty spring bucket and no bumpstops......the holes for the TB crossmember seem to be on the frame right behind the trans crossmember
kyle's v
Oct 4, 2015 12:37 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
Ketis
Jul 23, 2015 12:37 PM
85SS/85GN
Jul 22, 2015 12:48 PM
