Shorter/Adjustable rear upper control arms
Old Feb 16, 2005 | 01:28 PM
Mr. Sandog's Avatar
Default Shorter/Adjustable rear upper control arms
Went into the driveline place this morning and found out my 2/4 drop has screwed up my pinion angle, which is causing my vibration. Because I have coils in the back, I can't shim the rear like you could easily do with a leaf spring rear. Instead, my only recourse is to either lengthen the lower control arms (trailing arms) or shorten the upper control arms.
Since I have the Hotchkis heavy-duty lower arms, I'd like to keep them and find some uppers that are either shorter, or adjustable. Does anyone know of a place who makes these, has these, or could help with this issue?
Old Feb 16, 2005 | 02:16 PM
moregrip's Avatar
what a rush!
typically, if unavailable, you can make them by using threaded heim joints and a pc of steel with threaded inserts welded in.
Old Feb 16, 2005 | 02:25 PM
moregrip's Avatar
what a rush!
"Trailing arm brackets are also used to allow the axle to move up with the new coil springs. This bracket keeps the trailing arm at the correct angle"
http://www.djmsuspension.com/Product...-TahoeRear.htm
Old Feb 16, 2005 | 02:34 PM
moregrip's Avatar
what a rush!
One more, this looks like a good read:
http://www.lowridermagazine.com/tech/0303lrm_avalanche/
Old Feb 16, 2005 | 05:59 PM
Mr. Sandog's Avatar
Looks good, I will try and get this bracket - thanks.
Verz
Aug 21, 2015 06:40 PM
Allgonoshow
Jul 29, 2015 04:21 PM
Kaldar
Jul 27, 2015 06:42 PM
DONTH8
Jul 26, 2015 06:59 PM
Ketis
Jul 23, 2015 12:37 PM
